Online: wildchild
CVO Engines
  • outfitter444
    outfitter444
    Hi,
     Does anyone know what Harley do to upgrade their SE 110B engines that they put in the CVO’s or is it a standalone unit for the CVO models ???
     Does the 110 come standard with SE 255 cams ?
     Thanks
    Not sure what you mean ? The CVO 110 is the same as the SE 110 (stg 1) .
    Yes - SE255 cams.
    Edit: - There is a 110 stg3 race kit with higher comp' + SE259
  • outfitter444
    outfitter444
    Thanks guys that does help a bit, yes that question was a bit how ya goen but it all seems fine when its bouncen around in my head, to many Whisky’s I think lol.
    What I think I’m looking for is, If the SE 110 is stage 1, what goes into it (besides cash) to make it a stage 2 or a stage 3 and what sort of output gains do you get ?
    As far as the cam goes, if the 255 is standard in a 110, is it an option for other motors like a 103 or do they have a 255 as standard as well ?
  • outfitter444
    outfitter444
    Thanks Guys the last two posts got me to were I needed to be.
  • ucmitch
    ucmitch
    I am pretty sure a stage 4 103 will towel up a 110 cvo engine, if you are looking 103 upgrades, if you are are looking at 110 upgrades see above.
  • Retroman
    I have 2 CVO's , a 2008 CVO Springer and a 2013 CVO Breakout
    Springer has 255 cams as stock ( all CVO's do , it's called the CVO cam !) and is tuned with TTS
    Breakout has an " 1800 Pro-upgrade kit " which is 10.5:1 pistons , 259e cams and an SE Supertuner. Fitted from brand spanking new by the HD dealer
    Springer has V&H Big Shot Staggered exhaust system with the "power chamber" or crossover that connects the downpipes
    Breakout has Freedom Performance true duals , " Freedom Performance Declaration Turnouts" to be precise
    The Springer is a " Torque Monster" , down to the 255 cams and the "Power chamber". Pulls like a train but runs out of puff by 5000 RPM
    The Breakout has less torque low in the revs , but flies up top , 4500 RPM plus. Makes power to 6300 RPM like a Ducati. That's the high comp' pistons and the 259e cams
    I ride them one day at a time , then use the other next trip , so i can truly compare them , and each have merit.
    The Springer has far better " roll-on" torque and power so in freeway traffic etc it's actually " quicker " to hustle along
    On open road country runs the Breakout has the edge for sure , top end rules out there
    And for what it's worth BOTH can SPANK my mate's 2011 with the stage 4 103 Kit ( albeit that's a Streetglde which is heavier but has no Balance system to sap power !)
    Hoping that helps you a wee bit ?
  • outfitter444
    outfitter444
    Handy info Retroman thanks
