Online: wildchild, John.R
Chrome Drag Bars
  • T-1000
    T-1000
    G'day All,
    After some advice.....looking at sourcing chrome drag bars for a fxsb Breakout, as far as I am aware Harley dont make any....was thinking of gettin the original chromed. Can anyone suggest a place (sydney based) am thinking this will be pricey aswell?????
  • ucmitch
    ucmitch
    Hey Mate cant answer your Chroming questions however plenty of aftermarket bars available, all you need is 1.25 inch bar (or 1 inch with adapter) the only time bars get hard with the breakout is if you want to change your risers
  • T-1000
    T-1000
    Cheers ucmitch.......will take a look into it.....
