19" FRONT WHEEL
  • bikenut57
    bikenut57
    G'day all. Has anyone swapped the front 18" wheel on a Street Glide for a 19"? If so, would appreciate any feedback.
    Cheers, Bikenut.
  • gidgi
    gidgi
    I went up to a 21" on my 2012 Road king ..From 2009 up I believe the frames to be the same the only variation would be the fender.If you have ABS you will need to get a wheel with an ABS wheel bearing. I bought a Fat spoke wheel for my model ,it went straight on with original fender no Drama with brake calipers, literaly a couple of Hours Hope this Helps but do your homework ask around cheers
