Online: HD17
Installing Saddlebag Guard Rails on FLHTK 2014
  • jock01
    jock01
    has anyone installe \d saddlebag guard rails 90200561 on 2014 flhtk, having a probel with the right side the rail wont slide through the chrome saddlebag support as shown in the HD instructions ... i donwt want to take thr shockie off so any advice very welcome
  • markwoumla
    markwoumla
    Mate I cant help you much, but from what I read , the 90200561 saddlebag guard seems to be a pain in the arse to install. You have to put them in backwards, and then turn them around. One guy removed the right shock and said it was the easiest way to go. If you have a bike lift , it may be the way to go. Good Luck !!!
