Online: StephenB, beaglebasher, HD17, kocho, Muzza Wa, Rextheute2022
Wrist Pin Clips
  • Ando
    Ando
    Doing  A 107ci build on a mates Softy and got theses new wrist pin clips with the CP pistons, this will make things a lot easier to install and hope all CP Pistons I get in the future have this set up
    http://www.krammloxusa.com/installation.html
  • Koala77
    Koala77
    they look alot better to install than the KB wrist pins to install,near spat it on the first installment, but kept my cool cause there were 3 to go
  • Ando
    Ando
    Just installed them, fark it makes it a lot easier
    [URL=http://s307.photobucket.com/user/Ando1450/media/IMAG0727_zpse2085ea3.jpg.html][/URL]
    [URL=http://s307.photobucket.com/user/Ando1450/media/IMAG0729_zpseab10af6.jpg.html][/URL]
    What sort of piston to bore clearance have you got with that 107 ando?
    always put the gap in the c-clip facing  top or bottom only  ,   help's to keep the clip in place, just because it's called a C clip it should not look like a C
