shovel regulator
shovel regulator
kickinon
1979 80ci
kickinon
Chris,
its the other one with the 2 pins protruding from the rubber boot, l bought one today.. it should have been the one with the part number you showed, the motor l have must have been changed to a later stator at some time..hence the 2 pin set up in the reg..all good .......
