Online: Retroman
Footpegs for 48
  • ConR
    ConR
    Hey guys.  On the hunt for a set of new pegs for my 48.  Found tons that I would like, but none of them fit them fit the 48 for reasons I don't understand.  Anyone know why that would be?
    I love just Stealth footpegs from Harley, but they don't fit pretty much any of the Sportster range.
  • terroristone
    terroristone
    The peg mount is different. The top part extends out further than the bottom. An easy fix us just grind it to match the bottom and any peg will fit. Joker machine make done nice pegs but take way too long to get. I just recently got a set of speed merchant pegs and love them. I'm now a retailer for th also if you want a set.
    Regards Andrew
  • brash
    brash
    If you don't want to grind anything, figure machine make specific pegs for the 48/72, although they had so much slop when I fitted mine I was not happy at all. Had to use a washer to get it right.
  • AK47
    AK47
    Hi
    On the weekend I was at Frasers at Concord and spoke to Con the spare parts manager about this problem. He stated that they found the answer to rectify the issue as it was annoy a lot of harley 48 owners.
    The simple issue if you dont want to grind away then you can change the Clevis "Shaft that the Footpegs Bold to" from your current one to the Harley parts.
    Part Number H 42541-04 Clevis,Footpeg Rid Price $46.31 Qty 1 and H 42566-04 Clevis, Footpeg RID Price $46.31 Please note that most shops do not keep these in stock and they would have to order them in
    After this has been completed you can use the Footpeg that you choose...Hope this help.
  • sys7910
    sys7910
    hey is this foot peg you are looking for? rough crafts made in taiwan and there is my friend has this looks very nice. it could be fitted SPORTSTER DYNA MODELS, i need one too...
    http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=131242853001&ssPageName=STRK:MESE:IT
  • ConR
    ConR
    I ended up picking up the kit from Drag Specialties. Just waiting for it to come.
  • Trick
    Trick
    Used a dremel 4000 on mine cut the excess off like knife through butter. Don't be scared to cut and chop that's what customizing is all about.
  • brash
    brash
    I did this mod yesterday actually to fit my new hippy killer brass pegs, piss easy to do, 5 mins on the grinder each side and you are done. Took longer to find the grinder.
  • ninetynineco
    ninetynineco
    Those brass pegs looks awesome, Brash!
  • ConR
    ConR
    Man we ordered the same pegs haha. I put them on a couple weeks ago, but ordered the HD offset clevis kit.
  • brash
    brash
    Nice! Well atleast you know what they will look like once on. Not gonna be too good in the wet I reckon
