Online: wildchild
2007 night train wont start
  • billie
    billie
    changed the batteryNow it wont start kicks over ok can hear the fuel pump kick in plenty of spark. will fire ok if fuel is sprayed into throttle body but it appears no fuel from the injectors
    any clues or is it a trip to the dealer
  • cm364352
    cm364352
    Check the fuel line conection at the tank,push up on it as you try to start it.if you are sure the pump is working
    the relay should be ok.Cant see how it ties in with changing the battery though.
  • billie
    billie
    everythin was fine last time I rode the bike. sat for app 4 months. battery was a bit low so i replaced it ;I went to start it. kicked over ok but no start replaced the fob batteries, still in the same boat. I have checked all the push on around the theottle body all ok there to .It's got me stuffed
  • cm364352
    cm364352
    So you have checked the quick connect fitting at the tank?
    WAZ..
    how much fuel is in it
  • billie
    billie
    where is the quick connect? plenty of fuel just not comming through the injectors
  • 06 Softail
    06 Softail
    The quick connect is the chrome fitting directly under the tank on left side, & just above ignition coil and should be connected to the fuel line. Make sure it is connected properly, just like an airline quick connection.
  • robots
    robots
    hi,
    unplug the ecm and plug back in after a few minutes and see what happens, could be worth a try
    thanks
    robots
  • billie
    billie
    have unpluged the ECM over night  no joy. I will try the conector when next I am off duty,
    can the pump stuff up even though you can hear it buz up?
  • cm364352
    cm364352
    If your still running the original fuel filter that could be an issue.I would check to see if the fuel system is holding pressure
    before I went tearing into that though.Also have you checked for error codes yet.
  • billie
    billie
    no error codes; where is the fuel filter? I have never changed it,
  • robots
    robots
    Hi,
    Jesus this a ripper, changed battery for new one, bike cranks but not start, if spray fuel in throttle body it starts
    Fob battery changed
    All connections at throttle body checked
    Just go thru the motions of checking fuses again, battery ground and connections, see what happens
    Unplug fuel device if have one
    Thanks
    Robots
  • billie
    billie
    Thanks for your help guys I will be of on tuesday and give all your suggestions a go and keep you informed where is the fuel filter?
  • robots
    robots
    Hi,
    In the tank
    Thanks
    Robots
  • Bashful
    Bashful
    I am also thinking ECM. I had a night train do the same thing by the sounds of it. It felt like it was about to start but just couldn't quite get there. I had the luxury of having 3 bikes all the same model, I pulled the ECM and associated security components from one of the other bikes and installed them to the bike that wouldn't start and she started.
    Do you have the pin code for your HD security system?
    And buy a frigging manual!
  • Veteran
    Veteran
    Does it fire and then cut out without spraying fuel in throttle body ?
  • billie
    billie
    Well guys I think this old fart needs a hearing aid. Like I said I turn on the ingition hear what I thought was the fuel pump pressuring up but still no fuel.
    My old mate Piker comes around and said he could not hear the fuel pump working.
    Bullshit said I listen? Turn on the ingition and sure enough that noise that I thought was the pump comes in.
    Pikers comment!! you dick head that something to do with the alarm.
    So it turns out changing the battery had nothing to do with starting. Coincidently the fuel pump shat it's self at the same time.
    Cost of pump from harley D $340.00 BUGGER
  • Lushy
    Lushy
    injectors or pump is stuck from dried out stale fuel...
