Online: obisteve
Oxygen sensor adapter
  • Builder bob
    Builder bob
    Hi guys
    stupid me bought second hand set of  v&h  big shots black. Was told suit dynas 2006 up
     my 2013 fatbob has smaller sensors 12 mm???  Then exhaust has a larger thread size 18 mm ???
     Is there an adapter I can buy to reduce the thread to suit smaller sensors. ?
    Any advice would be appreciated
    if can't use them then up for sale.
    Cheers bob
  • Builder bob
    Builder bob
    Thanks speedzter
    have you used these?
    Looks like might save me a heap of lost $$$
    bob
  • Builder bob
    Builder bob
    Hilly no the front one is up much closer to the engine end of the pipe.
    Will probably be 200 mm short on lead
    man what a f##k up
    Should have asked first.
  • Builder bob
    Builder bob
    Thanks Hilly
    might be all too much hassle. Go back to my s & s slipons and get cat and flap removed. Will put the big shots up for sale. Have tts and a/c coming so is probably all for the best. More HP and less copper hassle
    bob
  • Builder bob
    Builder bob
    Hi Dynoharley
    thanks but should have been clearer.
    The lead will not reach now it is too short. Would need longer lead or to move the screw in the exhaust.
  • robots
    robots
    hi,
    get the kit, probably about $80-90 landed in Aus, plug and play
    thanks
    robots
  • Builder bob
    Builder bob
    Hi Robots
    which kit is that. The bass anti one? Please explain in small words as I am mechanically challenged. Hehe
    is it a kit with 2 screw in reducing adapters and a longer lead for the front sensor.
    Thanks for your feedback
  • Builder bob
    Builder bob
    Hi guys
    would this work?
    Categories
    Find My XIED
    Harley-Davidson
    BMW
    Victory
    Ducati
    Moto Guzzi
    Buell
    Husqvarna
    XiED Fuel Management
    Accessories
    Specialty Items
    Holter Vest
    Home > XiED Fuel Management
    12mm O2 sensor Relocation Kit
    Part Number 22
    Zoom
    Bungs and Harness Adapter
     Email a friend      Write a Review
    Price
    Your Price:   $31.99
    Availability:
    In Stock
    Share on facebook Share on twitter Share on email Share on gmail More Sharing Services
    0
    Quantity
     Description
    USE EARLY EXHAUST SYSTEMS WITH THE NEW H-D 4-WIRE HEATED SENSORS
    2007-2011 Dyna for 2012 Dyna
    2007-2011 Softail for 2012 Softail
    2009 Touring for 2010-2012 Touring
    Riders wanting to use an exhaust system from an 09 HD Touring bike on their 2010 and later H-D Touring bike could find this swap difficult because Harley changed the type of O2 sensor and the location of the sensors. The new Delphi 4-wire sensor is a small thread versus the more conventional 18mm thread of the in the earlier HD Touring bikes.
    Riders wanting to use an exhaust system from an 07-11 HD Dyna and Softails on their 2012 bikes could find this swap difficult because Harley changed the type of O2 sensor and the location of the sensors. The new Delphi 4-wire sensor is a small thread versus the more conventional 18mm thread of the in the earlier bikes.
    This adapter kit allows the relocation of the small 4-wire Delphi sensor to the position used in earlier exhaust systems using the 2-wire sensors. The relocation kit includes bung adapters and an O2 wiring harness extension.
    The 12mm O2 Sensor Relocation Kit is compatible with the FL-XiED-10 and FL-ViED-10, allowing Riders to richen their fuel mixtures.
    Other similar kits and 18-12mm bung adapters are made with mild steel. Our bung adapters are made with high quality stainless steel machined in the USA. Like all Nightrider.com Performance Products, everything is manufactured USA. Our kit might cost a little more, but it was designed to last as long as your exhaust system.
    For use on
    2010-2012 Touring to 2009 Touring exhaust
    2012 Dyna to 2007-2011 Dyna Exhaust
    2012 Softail to 2007-2011 Softail Exhaust
    Owner is responsible for proper fitament
    For Off Road Use Only
     Customer Reviews    Average Rating
        mr
         excellent quality product fast service definitely recomend
         Reviewed by:  Denis M. Martel from mass. on 5/10/2014
    Accessories
    FL-ViED-10
    Your Price: $119.99
     37 Review(s)
    FL-XiED-10
    Your Price: $119.99
    On sale: $104.99
     51 Review(s)
    Browse Similar Items
    Find My XIED > Harley-Davidson > Touring > 2010
    Find My XIED > Harley-Davidson > Touring > 2011
    Find My XIED > Harley-Davidson > Touring > 2012
    Find My XIED > Harley-Davidson > Dyna > 2012
    Find My XIED > Harley-Davidson > Softail > 2012
  • Builder bob
    Builder bob
    Cool thanks a heap Robots.
    I have TTS in the post on the way from us to go with pipes and air cleaner. Now I can still try the big shots out.
    Thanks heaps guys.
    Bb
  • ozymax
    ozymax
    Just get 2 x 10mm 02 exhaust Bosses may take some finding as 18mm seems to be more common either from ebay or the local exhaust shop and have them welded in at the required position, pick up 2x 18mm 02 plugs and screw in to the current bungs. Stay away from steel Allen head type bungs, you may never get them out with out destroying the Boss
  • Builder bob
    Builder bob
    Hilly
    what you are saying makes sense. The rear bung is in the same location as the original one. The front bung in v&h is 300mm closer to where exhaust meets engine than the stock one.
    Nightrider sell the kit with 2 adapters and a longer lead with electrical plugs for the front one.  Must be a few nuggets like me out there.
    Are you saying that the tuning won't adapt to the changed location of the front sensor.
    I would be happy to give it a go as I want to hear the pipes but am reasonably sure I will go back to the slipons after because of the noise factor.
    Now that you have brought the tuning issue up will know what is wrong if doesn't tune properly.
    ( have read too much good stuff to blame tts. Nearly always is operator error when components don't work)
    Thanks ozymax
    heaps of Allen head ones on the market so great advice to stay clear. Would only have to move one bung and swap out rear one if I could find someone to do it. Might try calling an exhaust shop.
    Any good exhaust guys northern adelaide ?..
  • Builder bob
    Builder bob
    Dynoharley
    the rear bungs are in same location   Front one is 200 - 300 mm closer to the head in the v & h than the stock one.
    will that affect readings dramatically
  • dynoharley
    dynoharley
    it will very minmal , i have played with o2 sensor tubes up pipes and started at 200 mm from head and moved it back 50 mm at time to 300 mm back and redone readings , and all good , but if it was all out engine then you would want the o2 at same distance from exhaust port , but then different shapes headers and lengths will change back presure to each cyclinder which controls what afr reading will be   , your eng would be fine , but the adaptors as some one pointed out nearly schroud the o2 sensors , have also been running o2 in my falcon eng naturaly aspirated in cyclinder 1 and 8  to get the long runners not to run  leaner than short runners   ,  to road tune compared  to dyno changed afr reading by full point , different air speeds and air presures to intake system change afr readings , forced induction at 130 mph at 400 mtr run changed afr readings to the stage it was running lean  , i will be tuneing my 2012 106 bike this way in next few weeks and compare dyno afr  readings at 6500 rpm compared to fast afr logger that i have , sounds like the the items found on night rider the go , , cheers
  • Builder bob
    Builder bob
    Thanks heaps for your input guys.
    Still think I will give it a go with the adapters first. If no good then will get them cut out and redone with the right size.
    Again thanks.
