visor scratch
  • 1elcys
    1elcys
    If its deep its fucked! buy a new one.
    If its not so deep you can polish them out but it is hard work in the long run its easier to just buy a new one.
  • 1elcys
    1elcys
    Unless you wanna be there polishing a visor all day.
    Myself I would rather pay the price get a new visor and then ride all day.
  • Phillthy
    Phillthy
    Get a new visor.
    I did the same and tried to buff it out.
    Have to buy a new one as now have an annoying smudgey bit and no scratch.
    Always happens at your eye line.
  • Cyborg
    Cyborg
    Brasso is good for somethings but  if you have it try it and if it doesn't work buy a new one.
  • gonzo
    gonzo
    "Mothers plastic polish" is good for shallow scratches. I bought a screen which had been marked down because of a scratch, and managed to polish it out with the stuff. I didn't expect to get a good result, but it worked well.
    Gonzo.
