Online: Stuart, Hilly, speedzter
Aircleaner
  • Builder bob
    Builder bob
    Hi guys
    after some advice and opinions.
    First up
    2013 fatbob 103
    have s&s slipons atm
    plan to purchase TTS from m&m usa
    have set of v&h long shots coming.
    Want to get andrews cam later on( 37 or 57 I think )
    I want to keep original air cleaner cover. Should I buy Allen ness one from USA or screaming eagle one from Peter Stevens. How often do I need to change filters. Is there much difference in quality or performance between them. They are within $10 of each other.
    If the long shots are too loud will get flap and cat removed from slipons. ( I know I know)
    thanks for your input guys
  • Builder bob
    Builder bob
    Thanks Hilly
    long shots came second hand. Wouldn't have even looked at them new. I know will lose a few hp but they look great. S&s slipons are just a bit too quiet. Have been told that with cat out and flap removed will sound marginally louder. Then the cam will give it that bit more.  That's probably how the bike will finish up. But  have to have a bit of a play and make a mistake or two before settling on best setup like all before me.  Hehe.
