Online: speedzter
Lost smart tune file
  • Luffy69
    Luffy69
    Hi
    did a data run the other day (sepst) ,got home and downloaded the run,when i went to upload smart tune VE table etc,but the file is no where to be found,searched through the computer for the file,still no good! Any ideas? This has happend twice now( the only 2 times ive done it)
  • harty
    harty
    I lost the same file a while ago but managed to find it. I found it by pressing the start button bottom left corner(i'm using windows7) and in the search box type .hdx (file type of the smart tune runs). This should bring up any smart tune files saved on your computer. "IF" it finds any files right click on it and click "open file location" and there it should be.
    Hope this gives you some success.
