Bike Table Lift - Tell us about yours!
  • the_mongrel
    the_mongrel
    So...
    I am in the market for a bike table lift.  I bought one already, but it's shit, and it's going back for a full refund.   It was off eBay called a MotoMax Table Lift.  Stay away from that shit!!  I mean... the lift itself is not bad... but the quality is shit.  Trouble is, it's about the only one I could find that is long enough to fit my bike.
    SO.... If you have a table lift, tell me about it - Good or Bad - as I need to know.  :)
    Mongrel
  • FXST11
    FXST11
    Hi Mongrel, Did you get it from Newcastle. If so I was going to buy one about 18 months ago from them. I asked a few questions regarding length etc and what they told me , Contradicted what was on their web site. I queried that and they did not like that and got abusive.
    What exactly was wrong with yours, How were you not happy?
  • Hound_Dog
    Hound_Dog
    I have a Kendon Cruiser Lift. Very well made, strong, stable and of very high quality. If you have limited space and want something that can be easily folded up and stored then this is definitely the go. Lots of accesories also like frame jacks, service trays, drain pans etc.
    http://www.hartstransport.com.au/lifts.html
  • chriso
    chriso
    bought mine for $250 bucks. It was to short as well so I just welded some 6 mil plates on it, painted em and changed the wheel brace thingy to one I bought new for $40 .
    good for the price I reckon
  • Ando
    Ando
    This is mine its heavy duty was quite expensive had it a couple of years now
    [URL=http://s307.photobucket.com/user/Ando1450/media/WP_000697.jpg.html][/URL]
  • the_mongrel
    the_mongrel
    Thanks guys - Keep em coming!
    The lift I bought was a good length, but the problems are many...
    1) The Ram  leaks oil like a bitch.
    2) The clamp the holds the wheel is fubar
    3) I can't lift the table too well because the handle hits
    4) Screws missing and stripped.
    See the pics attached - I cracked the shits and they are picking it back up today.  Fuckem!  It's a peice of shit.
    So now I need one that is long enough for my Fat.  Most of them are 1800 and that's too short.  I need one that is 2200.
  • jacko88
    jacko88
    had this one for 8 years approx easy one man operation and worth every cent
  • grahamjb
    grahamjb
    That is one hell of a clean workshop BDA103
  • chriso
    chriso
    Guess its gonna come down to how much ya want to spend cause looks as if they range from $250 - $2000. I cant come to spending $2000 when its just me fucking around in the shed occasionally. Be different if i was doing mates bikes all the time or doing it as a business.
    But if i had me time over id prob go mid range for about $900. there seems to be some good ones out for that price.
  • the_mongrel
    the_mongrel
    I like that MC615R, but it will cost me nearly $3k by the time it gets here - Not a chance!!!
  • jacko88
    jacko88
    Mongrel paid 1650.00 for mine new ended up 2100.00 delivered from Qld to WA not sure what they are worth now, I  tried that cheap shit before this one and should have brought the better one first as there is a major difference in quality and performance
  • the_mongrel
    the_mongrel
    Thanks Jacko,
    I called them today - The lift is $2500 + plus the wheel clamp + Shipping. Just too much for me man.
  • jacko88
    jacko88
    that's a bugger mate, who did you ring?
    have look on fleabay there is a few good looking Chinese ones on there liftking,herohoists , still up in price but you may save a few dollars
    burnzi put up a do it yourself lift table site a few mths back I was going to make one of them a few years ago if your handy with a welder or
    know of some one who is you could probley make one for $500 with wheel chock/holder simler to whats on jackos from supercheap $80
    what ever lift you get you need a sissior jack aswell and a few tiedowns
    those yellow ones are the same as  the red ones you see around cheap made for lite bikes which may go on once or twice a year
  • Ando
    Ando
    Try the mob that BDA and I got mine, BDA posted the link to there website
  • Burnzi
    Burnzi
    Not all that high but an easy shed build lift that utilises your trolley jack as the lift
    http://www.afabonline.com/cycle.htm
  • the_mongrel
    the_mongrel
    So stupidly, I am still in the market for a lift. I like the look of the Kendon, but it looks like it would tip over easy. How stable are they?
  • 45WL
    45WL
    Mongrel
    I've had my Kendon for over a year and its the best piece of kit I've bought. Ive had my 45wl, sportster and WG up and no problems. Traded my WG in on a breakout and I've had the BO up to change pipes and clutch cable no issues at all. Next upgrade is cams - all of which would have been impossible without my kendon. I wrote a review on this forum shortly after I bought it - http://www.hdforums.com.au/Default.aspx?tabid=71&forumid=37&postid=509570&view=topic
    My opinion still hasnt changed.
