Online: Stuart
TTS Whats to come
  • Ando
    Ando
    This little comment of another forum is this true,,,,,Steve
    You say that the histogram for spark logging is not available "yet". Does that mean it is coming with VT3? In VT3 I have heard auto EGR adjustments and timing assist (what ever that is). Maybe I'll just need my iphone for VE histograms. I don't know if VT3 new features will work with the black dongle however. Thanks again.
  • Steve Cole
    Steve Cole
    Let's just say lots of things are going to change once, its all working as we hope. The updates have been out for 10 days now for the 2015 model year. So now that is out of the way were back working on the new surprises for you all.
    Will these future changes work for the older bikes with the black of blue tts?
  • Steve Cole
    Steve Cole
    I do not know that answer just yet. Some features will not work at all as they require the Green interface, some will require the Green or Blue interface while the rest of it is still being worked on and I just do not know for sure yet.
  • Steve Cole
    Steve Cole
    It will be out once everything is working as we want it and it get's through Beta test, no sooner or later.
  • HogBag
    HogBag
    Hilly for what if worth I have had zero problems with my Vtune running out since I went with my 02's mounted straight into the header pipe with all the sensor in the exhaust flow. My bike has the old black tts tuner and I believe that once the 02 are mounted correctly the bike will self tune with good samples is it does detuning with bad samples over time. Don't discard the old just yet.
  • HogBag
    HogBag
    I should also add that over this time I have been running a bassani road rage 2 into 1 exhaust system that I fitted a supertrapp baffle with 24 discs closed to help with noise and 02 sampling.
  • HogBag
    HogBag
    Sparra sorry mate for not getting back to you sooner its completely standard bassani road rage with a 4 inch trapp fitted 26 disc closed cap. Let me know if you need any more info and I point you to a thread on HTT.
