I just can't get my head around it
I can't work out even how to write down what I want to ask
if you have marks to the left side of the red line on the anyliser what do you do to the EGR table to make the correction?
Is the idea to get all the marks that are on the left to the right of the red line?
Adjusting the EGR tables lower does that reduce the marks to the left of the red line?
a step by step with pics would be good to get my head around this
It does take a bit of brain power to get the head around the EGR process. What is a bit of a brain tease is that not all the RPM points on the VE tables match the EGR ones. Hard to explain the process off the cuff, but here goes, & I hope it makes sense. Once you've generated the vtune map, click on settings, then click on High Light low MAP. This will show some of the VE’s in bold numerals. I guess you could say that the bold numbers are to the left of the red line on the EGR analyser. Going along one column at a time, find the percentage difference between the last bold VE number in that column & the next VE number (non-bold). After you've got the percentage amounts for all the columns, add each percentage amount to the appropriate RPM point in the EGR table. With the RPM points not all matching in the VE & the EGR table, it becomes a bit of a juggling act to average out the figures for some of the RPM points in the EGR table. The idea, I think, is to get the dots onto or to the right of the red line in the analyser. This also smooths out the VE tables so that you see smooth waves in the VE graph, rather than sharp peaks, & it really does smooth out the engine, especially @ cruising speed. I have an Excel spread sheet I down loaded off HTT that I use it to help with adjusting the EGR tables (another thing to get your head around). Tried to attach it here, but it looks like I will have to PM you a copy if you would like one. - Rob
and I mean raise or lower the % difference in the EGR table
i gave up trying to figure out what was happening with the line.
Pretty good method by Mayor on HTT for adjusting VE's for EGR
Adjust as required to get the last highlighted VE within 10% of the next VE in the rpm row
VE's are usually increasing across the row in highlighted area , so within 10% on the low side of the next VE to maintain the trend
so you're actually smoothing the VE's while adjusting for EGR
