Online: WideglidingNZ
Panhead clutch with mousetrap
  • Dodgy
    Dodgy
    I have a 59 panhead with a mousetrap. I want to change the clutch over to a Barnett Scopion or Rivera Primo Pro clutch and still retain the mousetrap.
    I have contacted both companies and they both say that their clutches "should" work fine.
    I have read that the mousetrap needs a heavier spring pressure to work properly.
    Does anyone have first hand experience with either and can confirm if they will suit please?
  • Dodgy
    Dodgy
    Thanks Bob, decided to go with the Barnett Scorpion. Looks like a better unit. Also comes with all the higher pressure springs.
    DD
