Online: HD17
80 cube evo unknown cam and solid lifters valve clearance ?
  • RATTY
    RATTY
    Helping a mate with his bike have found the the cam isnt standard as the owner told me the bore was just honed to clean up heads where serviced but valves are running tight as lifters ae solids and adjustable pushrods does anyone know what clearance I should be looking for have searched but couldnt find the motor is in a custom frame so vintage is unknown but a guess would be around a 1996
    Adjust when cold, lifter on the base circle of the Cam, and aim for a slight drag when spinning the push-rod .
  • RATTY
    RATTY
    is there any thou adjustment or just by feel ive always had a measurement ans was going to check the measurement at the valve to rocker clearance
  • sag57
    sag57
    Rat as speedster rightly said you adjust solids by feel, if you have never adjusted solids before, chase up an old school mate and get him to show you, and all will be revealed. Personally l would buy a set of factory hydraulics set and forget . especially an evo ,tough as old nails
  • RATTY
    RATTY
    Thanks guys always thought a feeler guage would have the last say but then by feel it is. At 52 never to old to learn a new trick
    hey ratty is that you its me bob,  not very often you find solids in & EVO  ? are you sure there solids
  • RATTY
    RATTY
    gday bob yes its me am not sure if they are solids but have treated them as they are and works well to have 2 lifters that dont pump up is unusual it was built by sys head mechanic 10 or 12 years ago had a bent pushrod 6 months ago then the owner took it to someone who put adjustables in and was told then what they where will call you today when work slows down a little
