Online: Kato
shiny bits in the 07 tranny?
  • rooshooter
    rooshooter
    18 years ago
    finaly got my bike back from dealer after they had it for nearly 8weeks
    i was not happy with the length of time it took to replace bearings in gearbox....
    but it was great to take a ride with a few mates.just come home after 2500km long weekend
    turns the speedo around to 16000 kms so in keeping with the  service sched i have taken on, i changed all the oils
    i dont believe it.......   there is shiny shit at the bottom of oil container used for draining transmission oil
    you can see a mixture of silver + bronze dust in the oil
    there is only a small amount but i certainly didnt expect any.
       any  suggestions  ?
  • rooshooter
    rooshooter
    18 years ago
    no doesnt seem any noisier than usual
    im thinking of running it for another 2000kms then changing the oil again + have another look
    isolation is my biggest problem livin out in the scrub
    i guess if there is crap in the next oil change ill hav ta take the thing to morgan+wackers in bris 650kms away
    at least i have plenty of warranty left and spoke to serv tech at above shop yesterday,they dont seem to have a problem with me servicing the bike as long as i use gen parts
    i was a bit concerned that i may have some probs with warranty not being able to get to a dealer for every service
  • rooshooter
    rooshooter
    18 years ago
    hey fatboy
    what the hell is a speed pick up sensor and i told dealer i have been using screamin eagle syn oils in all holes
    would have liked to have tried amsoil in trans but worried about warranty issues
  • rooshooter
    rooshooter
    18 years ago
    thanks fatboy will check it out today
    by the way what oil da ya run in your tranny and does anybody know what the story would be with warranty if i used non gen harley oil?
