Online: beaglebasher
Burly Sportster Short Sissybar
  • Bear2009
    Bear2009
    Purchased the Burly Short Sissbar and attached to my bike today , it's a one piece sissybar , well designed  and only took about 15 minutes to attach, took longer to find the bloody tools than to attach the bar , only one thing they need to add is maybe some rubber washers to protect the fender if you want to remove it later on, but pretty happy with it , will upload a photo of my bike when I get a chance , stole this one off the www.getlowered.com  cost me $240 delivered to Aus  which was about $10 cheaper than the Burly web site
  • terroristone
    terroristone
    Wow! that looks nice, i like the look of the high one as well. Are you able to measure the width of it where it bolts to the strutbar?
    Regards Andrew - T1
  • Wimbo
    Wimbo
    Im pretty sure I could locate that on my EVO rear guard, (Custom).
    Have you got the Width dimensions please mate and hole width?
    Cheers.
  • Wimbo
    Wimbo
    Found out, too wide, 12.5 inches, bugga.
  • Colstah
    Colstah
    Too wide?
    Vice and a mallet will fix that!! :)
