L-Joint, Fuel intake
  • Koala77
    Koala77
    Hello to all,
    I would like to ask anyone if they have replaced there L-joint, fuel intake on an EVO carbie,
    my old plastic and brass one has perished and leaks fuel, I have a replacement brass one,
    any tips or recommendations would be appreciated.
    thank you Corey
    yep easy with carb of , break the rest of the plastic off put knurled brass part in vice and twist it left to right whilst pulling,
    to put new one in put in freezer for awhile than line it up where you want it to face than knock it in easy all done
    new oem one should be all brass
  • Koala77
    Koala77
    Thanks a million perthhog,
    my oem part is in freezer heading out to shed
  • Koala77
    Koala77
    New part installed, thanks again perthhog :-)
    no worries glad you got it sorted happy days
