help replacing centre console insert RK
  • Canetoad
    Canetoad
    Hi folks,
    I have put a couple of dings crying in the pretty alloy console insert on my 2013 RK and I was wondering how difficult it would be to replace? has anyone had to replace one before, can you just somehow prise the insert out? any hints would be appreciated..... thanks in advance.
  • Chaser
    Chaser
    Take the entire console off to have a look. Should only be 2 screws or so. I have removed a softail and Ultra console before and they were dead easy.
