Dyna Wide Glide
  • GPM
    GPM
    Hi, I am new to this forum & for that matter new to the HD experience. I really like the style/look of the Dyna Wide Glide and would like to purchase one. However I am not a fan of the Tommy Gun exhausts.
    Hoping someone can give me some advice on wether its possible to fit an alternative exhaust to the Wide Glide to get back to that original Harley rumble without impacting on the bikes performace etc.
    Regards
    Graeme
  • Denoz
    Denoz
    Yes as chinashop bull said the sky is the limit if you have the money! when I done my bike (2012 wide glide) had to change air cleaner when I changed the pipes and also had to buy a tuner to tune the bike after fitting the pipes and air cleaner. In the old days you could just rejet the carby but with fuel injection you need the tuner. Cost me about $2500 for everything. but the bike does run a lot better. Or you could just change the rear baffles/mufflers witch is cheaper. I also done it this way first but was not happy with the outcome. So then I went the whole hog and changed everything as above. Now I have that RUMBLE!
