Online: Retroman, John.R, Hilly
48 Drag bars
  • slippy46
    slippy46
    Hi guys.
    I'm new to this Harley stuff so please go easy on me!
    I have a 2011 48. Just bought drag bars for it but upon installation they won't fit. Only 24'' long :S The brake master cylinder fouls on the fork top!
    I've done some more research and looks like I need about a 28''-30'' bar.
    I've searched Harley parts finder but can't find what I want.
    Basically I want shortest drag bars that will fit with minimal amount of pullback.  I don't like the really long ones with huge amounts of pullback!
    Can someone guide me in the right direction and or give me harley part number or link to where I can buy another set!
    If anyone wants a set of Biltwell 24'' drag bars I have a set for sale haha.
    Thanks in advance :)
    I sell Chrome 31" Long 1" Dia with 5" pull back. $40.00 VPW 03 8405 9212 .. If you want Black you just take the to you local Powered Coater with $10.00
  • 2014sporty
    2014sporty
    Search for broomstick bars, 0 rise and 0 pull back basically... Or cut down a broom stick and paint it black hahaha
  • 883n Harley Convert
    883n Harley Convert
    I actually ran a 580mm broomstick bar on my Iron for a while, I loved it......................everything was tight as fuck though, the master cylinder was basically an inch or two away from the centre clamp!
  • slippy46
    slippy46
    Cheers guys! Broomstick bars!!!
  • Bandageboy
    Bandageboy
    I have drag bars on my 48, the solution is to get a braided break line and that will sort you right out. Got mine here: http://www.helperformance.com.au/hel-brake-lines-for-harley-davidson-xl1200-x-48-2010-2011.html Great quality stuff, only found that the standard 48 brake line from them is a little long as it is for standard bars and does not count for the dropped bars. I have a black 48 and ordered a red cable, get tons of comments on the cable :)
  • mitch199
    mitch199
    If you were interested in a Genuine HD part, my bars are Harley PN: 55800035
    Sometimes Harley has genuine parts which are exactly what I'm looking for.. like these. 0" rise, 4" pullback (may be too sweeped for you?) and 29" wide.
