Online: GGUser731
What's that sound?!
  • Hooters
    Hooters
    Just wondering what makes the sound after you turn on the ignition.
    the noise made by my bike(48) seems to have changed recently and I'm wondering if there may be a problem.
    The fuel pump priming sound?
  • Hooters
    Hooters
    Is that what it is?!. What ever it is it sounds different now to when I first got it. It's sorta slightly squeaky/ raspy.
  • brash
    brash
    should make a whirr and a sort of a sucking noise.
  • Hooters
    Hooters
    Yeah the whirr is sorta squeaky. Could the fuel pump be on the way out?
  • 2014sporty
    2014sporty
    How olds the bike? My fuel pump makes odd noises when it primes too if I don't ride the bike for a few days or so and it's only 6 months old :/
  • Bear2009
    Bear2009
    My 48 does the same , fuel pump primes , sucks and squeaky noise , spoke to Hd mechanic , said nothing to worry about , it's from not riding everyday
  • Hooters
    Hooters
    Thanks for the info guys. I've been riding it a bit lately and it's back to normal. I also replaced the battery so I'm not sure if that may have helped.
  • C-Train
    C-Train
    My Iron did that after a few months, and usually when I hadn't been on it for a week or so.
    I'm sure it was the fuel pump. It always started fine though.
    And that's why we run Carbs! Lol
