Online: speedzter
ignition problem
  • jungle
    jungle
     g,day people , have a problem with ignition turn the key and it stays on lock , its been happening for a while but usually after a few goes it works , the bike is a 2010 fatboy ,has any one had this problem , or know how to fix it , thanks in advance , j
    HD will probably charge you a arm and a leg to replace it, perhaps a Automotive Locksmith.
  • beaglebasher
    beaglebasher
    have you tried spraying it with wd40 ?
  • jungle
    jungle
    no beagle but i did try contact cleaner  ,no result ,will give machanic a call tomorrow , cheers j
  • beaglebasher
    beaglebasher
    it sounds like a mechanical problem with the ignition. I would try wd40 before I went to the mech. cant hurt.
  • jungle
    jungle
    ok beagle , will grab some the w/s tomorrow morning , j
  • beaglebasher
    beaglebasher
    let us know how you went j.
  • jungle
    jungle
    no worries beagle , spoke to machanic , told me to disconect wireing loom to ignition and hot wire it, if it does,nt fire its ignition ,if it does its shitty conection , will be onto it tommorow ,cheers j
  • beaglebasher
    beaglebasher
    sorry about the bum steer j. I thought you were saying the switch itself wouldn't turn. (locked) keep us informed. I would have thought that if you hotwired it with the ignition disconnected and it fired then the ignition switch would be the problem. let us know how you go
  • jungle
    jungle
    well looks like the problem is solved , fob battery is weak , just have to get anew one sent out ,but pretty sure its the problem ,thanks everone for your input ,j the dc !
