Online: John.R
Best motor cleaner
    Gents the best motor cleaner is........?
  • 92Fatboy
    92Fatboy
    petrol and gurnie
  • Neale
    Neale
    If you have a silver motor, like me, wash it down with household grade kero and a clean paintbrush, hose it off, then use s100, then dry with a leaf blower. Works for me.
  • chopa
    chopa
    I just done my black motor. First I mixed CT18 truckwash with water in a sprayer@ 50/50 then washed it off with a pressure washer then I dryed the engine with air compressor.
    Then left it in the sun for an hour just to make certain it was dry then sprayed harley engine brightner on it as per instructions. Left it for an hour then started bike and when for a run.
    Was very impressed with the result. DON'T SPRAY ON HOT ENGINE
  • graz
    graz
    WIFEYsmiley
  • Aunty X
    Aunty X
    Believe it or not... it's piss.
  • Ando
    Ando
    export degreaser copressed air to dry of then export tyreshine
    its the cheap shit from supercheap auto
    C-18 is the Best
