Advice wanted please
  • Blacklable
    Blacklable
    Hi all,
    I'm a "Newbie" to the world of Harley Davidson.....having finally purchased a Softail after years of "Dreamin"
    However, the bike i've bought (knowingly) has been classed as a "Statutory Write Off", due to damage to the frame.
    My intention is to buy a new frame, and re-build the bike as standard, and have found someone who can supply a frame, ADR approved.
    My question is: After swapping everything over from the old frame, is it just a simple matter of getting it inspected, in order to register the bike for road use ? Or is there any other problem i might face?
    Your help would be appreciated - Please reply to: xxxxxxxxxxxxxxxxxxxxxxxx
    Blacklable
  • kingchops
    kingchops
    Blacklable,
    The whole concept of a forum is to discuss things on the forum, not through email. So I've removed your email address.
    It's also a privacy issue as anyone who responds through email exposes their email address.
    Thanks,
    KC.
  • Blacklable
    Blacklable
    I hear you.....No problem. New to this so slap on the wrist taken !!
    Welcome to the forum Blacklable.... one question that may be pertinent... what state do you live in (as opposed to drunken state looking at your forum name)
  • black29d
    black29d
    Hi Blacklable
    Sounds like a good project, but you may have a hassle with the engine numbers, if the bike has been a S/W then the engine number would be listed
    S/W cannot be rego'd to stop the rebirthing of stolen bikes, so I would check with the law about building a new bike with the old engine before spending good money
  • homerd
    homerd
    Welcome to the forum blacklable. Can't help you there buddy,
  • Blacklable
    Blacklable
    Hi,
    I live in Brisbane, Qld........would that make a difference ?
  • Blacklable
    Blacklable
    Haven't bought the frame yet......but the supplier will more than likely be Attitude Motorcycles......they make frames for most bikes, are ADR approved and come with manufacturers statement of origin
  • toxic
    toxic
    as stated b4, I'd make lots of calls b4 spending any more hard earned, if it's been written off, then the idea is it's not suppose to be re-registered, isn't it ?
    you might get the whole thing finished only to find ya can't get it on the road.
    BTW welcome to the forum
  • twincam88b
    twincam88b
    Interesting problem, will be interested to see where it ends....welcome anyway Blacklable
  • wally
    wally
    G'day Blacklable,
    in the west , we put an application to the dept vehicle safety and standard tech section and get a referance #
    to build an individually constructed vehicle. It must must have a report from an engineer to say it meets all adr standards.
    A vehicle identification number is then issued , this will be a brand new motorcycle and you won't be able to rego it as
    a harley . I don't thinkthe eng number will be a problem if its from a written off unit and legit.
    Then put it over the pits and get it licensed ,  its that simple .
  • Blacklable
    Blacklable
    Hi Wally,
    well, that's what i thought too.
    When a vehicle is registered for road use, as far as i was aware.......they only use the Frame (chassis) VIN number - not the engine ........same as with a car. Anyone can put another engine in a car from any vehicle, as long as it's the same as the original
    Anyway, will make a few more enquiries......just to make sure
    Thanks for your reply
  • hutch82
    hutch82
    All states are different but i would just give the RTA or transport dept. a call and they will fill ya in on what you need.
    Can't see too many issues though as heaps of people change engines and frames all the time. Probably just need engineers cert or similar and then pay all the bloody taxes involved.
    Good luck man.
  • Blacklable
    Blacklable
    Hi everyone.....
    just providing an update for all who are interested in my situation with the write off
    After discussions with Queensland Transport, it would seem that as long as the frame meets with ADR requirements, they don't see a problem with fitting the engine and all the bits and pieces.......provided it meets the inspection requirements.
    So, looks like i might be in Harley Heaven after all !
    Might take a while.......but i'll get there !
  • rkc07
    rkc07
    My only advice .. as with all things
    GET IT IN WRITING
    but good luck with it anyway
  • Blacklable
    Blacklable
    Yes.....i agree.........Damned Right i will
  • toxic
    toxic
    good luck with the build, should be one hell of a project bike
