Sena 20S Headset
  • Ginge
    Ginge
    Hi all,
    Just wondering if anyone has purchased the new Sena 20S bluetooth headset - as it is supposed to be the bomb!
    if anyone has go/used one, I wouild like to know:
    1. which style helmets will it fit other than a full face.......
    2. Where can they be purchased in Oz
    3. What is the cost as I researching online I have come across may different figures.
    Thanks
    Ginge
  • FXST11
    FXST11
    You could google and find Importer / Distributor in Oz. Then they can tell you your closest Outlet. and possibly the Cost.
    edit,  Looks like about $389. single pack and about $625. dual pack.
    try,    www.mototcycleracegear.com.au   in Melbourne
  • Ginge
    Ginge
    Thanks
    A few of us have the Sena 10H , and are very happy with them . About $400- a pair .
  • Blown66
    Blown66
    The 20S does look the go but it looks like they have been released yet.
  • imoo6170
    imoo6170
    Just saw an ad that they will be available post 23 June. You can order one via http://www.mrmobile.net.au/
  • imoo6170
    imoo6170
  • Ginge
    Ginge
    I appreciate the heads up. I'll check it out. Thanks
