Online: Soapbox2627
removing stock hand grips?
  • Daggs
    Daggs
    18 years ago
    Howdy all,
    is there a way to remove the stock rubber hand grips from my street bob without cutting them off?
  • Harleyglide
    Harleyglide
    18 years ago
    I don,t know a good way to get them off.
    But when I put new ones on I use hair spray, it helps them slide on then sticks em.
  • Daggs
    Daggs
    18 years ago
    had a quick look, good guide that one, cheers.
  • Daggs
    Daggs
    18 years ago
    yeah, i'll be trying that first
  • Paul.C
    Paul.C
    18 years ago
    Daggs,
    Lift it up a bit and stick the little red tube that you get with a can of WD40 and spary some in, then twist the grip a bit and then spray more in.
    This worked easy for me.
  • rooshooter
    rooshooter
    18 years ago
    yep started an opening with an old hacksaw blade thats filed down to get in between the grip + bar then the wd40 trick worked for me
