Online: Hilly, speedzter
Sputhe positrac
1/3
  • Daggs
    Daggs
    Just finished fitting the above stabilizer to my street bob, that rear one is a pain lol. Will hopefully test ride later today after a few domestic chores get done to keep the little lady slightly happy !
    Interesting to hear your comments.
    The True track made a huge difference to my FXDX.
    Also just fitted a steering damper to help with the pitiful roads we have now.
  • Dutchy Hoogen
    Dutchy Hoogen
    Daggs it's anything like the true-track you will be happy. Helps with the shit roads we've been riding
  • Daggs
    Daggs
    Yes it should be a good addition, haven't tested it out yet, will go for a spin after work tomorrow..
  • 45WL
    45WL
    Hey Daggs - what the go with these? positive /negative? would you recommend?
    Thanks
    45WL
  • Daggs
    Daggs
    G'day mate, haven't had a chance fir a test ride yet, been doing some long hours, will let you know after the weekend.
    By all reports they make a huge difference, especially if you push your bike pretty hard.
  • beagle
    beagle
    There is also a new dyna front mount developed in UK with a built in stabilizer. lotsa guys in the states are swearing by them. Google predator mounts.
  • chriso
    chriso
    had sputhe on for over a year now. Best handling upgrade you will ever do mate, would not have a dyna without one
  • 45WL
    45WL
    Look forward to the review
    @Chriso - did you upgrade the front / rear suspension or install a fork brace?
    Thanks
    45WL
  • chriso
    chriso
    mate i put the ricor intiminators in with the stock springs. I also put stock wideglide tubes on cause they are 2 inches longer then the fatbob ones and jack her up giving me more clearance. Was sick of scraping .
    Also have Ricor shocks on the back, half inche longer then stock again for clearance. it is perfect and still looks good the way it sits, actually ya wouldn't know it to look at.
  • Daggs
    Daggs
    Just got back from a quick test ride, you can sure notice the difference, bike vibrates less through the whole range, from idle and up and it feels like its on rails now through the bends.
    So yes I'd say its o worthwhile addition to the list of extras.
  • 45WL
    45WL
    Thats why I hate this forum.... just when you think you finished..... someone puts up a "have you considered this" post and the dollars fly lol!!!
    I was thinking of doing the front and rear suspension in anycase but If I were to stage improvements what going to have the most improvement on handling suspension or sputhe (or similar)???
    Was on the ricor website - great read = more dollars :-)
  • Daggs
    Daggs
    Progressives new gas charged drop in cartridges are next on my list
  • Dutchy Hoogen
    Dutchy Hoogen
    Did not notice any less vibration with the true-track, But handling much better. If you hit bump mid corner you only get the bump not the wobble wobble wobble can get right back on the gas.
  • 45WL
    45WL
    Daggs & Chrisso: what did it put you back and where did you order it from ??
    Thanks
    45WL
  • chriso
    chriso
    Ordered mine through Allan himself
    http://www.sputhe.com/index.html
  • 45WL
    45WL
    been looking at both the true-track and the sputhe
    pretty much look the same to me??? any advantages / disadvantages going either way ???
    45WL
  • Daggs
    Daggs
    I decided on the Sputhe as they both have good reviews and I think it looks better. Also I have heard that oil coolers fit better with the sputhe so that's a consideration as well.
    I tried buying mine from the man direct but had no success.
    I saw on his web site that he now does orders by email which I knew previously he didn't. After sending 3 enquiries by email over a couple of weeks and not getting any reply I tried ringing him a few times during US business hours and all I got was a recorded message telling me to email him...
    What The !!!
    So .... that made me almost buy the true track but tried looking elsewhere on the web for the sputhe and ended up finding a seller on US eBay that stocks them so bought from him. Same price as on the sputhe web site so should have done that about 5 weeks earlier... I hate getting messed around once you decide on something and have the cash ready...
    I'm sure they both work as good as each other.
    I had heard a few negatives about Sputhe service and the difficulty in purchasing.
    That and only good reviews from True Track, along with being able to purchase from M&M, the deal was done.
1/3
