Online: Hilly, blueystar
V & H FP3
  • Peterdk
    Peterdk
    The FP3 arrived today, so far I am very happy with it.
    Installation was very simple, remove seat and plug in. Turn ignition on and pair with iphone (or android).  Once paired, open the app and put in details from drop down choices,  bike - pipes - baffles - engine.
    The app then downloads the appropriate map in a few seconds and then select install map. First it uploads your original map the their server so you can retrieve it later if needed, then flashes the new map.
    I have only taken it for a short testride so far with great results. I was experiencing severe popping on decel since installing straight shot slipons, straight away this was gone. Bike sounds a bit better and seems to run a bit smoother. Time will tell how the fuel economy is, hopefully will improve a bit as well.
    I will run this map for a week or 2 then try out the autotune feature.
    Update in a few weeks.
    Peter
  • markwoumla
    markwoumla
    Hi Peter, I take it you have the V&H FP3 installed on a Heritage !! Can you give a run down on motor mods etc !!! Have only read about this tuner on the USA sites. The feed back from what I read seems all good !!! Another Tuner / Auto Tuner for people to choose from. The technology is sure ramping up on all tuners / auto tuners on the market these days. Look forward to your updates !!! Cheers .
  • markwoumla
    markwoumla
    PS , I just noticed your bike details at the bottom of your post !!!!
  • markwoumla
    markwoumla
    Some info regarding the V&H Fuel Pack FP3 .  Check out Important Notes,   there are some positive and negatives,    If your only going to Stage 1 , it is another option.
    Look forward to your results Peter !!!
  • SuperGlide
    SuperGlide
    it covers basically what most will use a PV1 or PV2 for anyway so they are pretty good and certainly presumes you are buying one to utilise ur smartphone.
    i think they're pretty cool and have'nt had any complaints,
    if planning a big build then you will definately need proper tuning down the track.
  • Lodgie
    Lodgie
    Do you leave it on the bike full time does it fit inside the box easily?
  • Lodgie
    Lodgie
    That's cool. Definitely like the idea of being able to tune it on the go.
  • upstart
    upstart
    Still happy with the fp3 Peter?
