Online: softfat
trans oil
  • PaulT
    PaulT
    HD recommend 20W50 oil in the transmission but from what Ive read, 75W90 gear oil such as Mobil 1 or Redline makes for a much smoother shifting tranny and better protection. True? it must be coz I read it, anyway where can I get Redline Vtwin shock proof trans oil in Brisbane, or Australia for that matter?
  • Ando
    Ando
    If ya want redline try conventries or google them for a distributor
    Redline.... It's in short supply at the moment but you can score some on eBay fur the same cost
  • petebob
    petebob
    Burson's stock Redline Heavy Shockproof.
    its pretty exxy, but Ive had it in the bob for 7000km and definitely noticed smoother shifting & less clunk when dropping it into 1st gear.
  • mickle
    mickle
    Yep, GL Lubricants are the go, get all my oils from them for a couple of years now.
  • Bashful
    Bashful
    Yep, I have started using Redline, at first I thought no biggie but since riding a mates bike and then getting back on mine the gear box is defiantly smoother. Both bikes were low kay late model Night Trains. I bought it at Bursons.
  • PaulT
    PaulT
    Thanks I ended up buying Amsoil for the crank case, and Amsoil severe gear 75w 110 for the transmission, I assume its as good as Redline in the gear box?
