Online: softfat
Dyna LED Turn Signal Drop-ins
  • OzDarchangel
    OzDarchangel
    Hi guys, looking for some advice on LED turn signals. I've got a 2014 Super Glide Custom and I want to replace the stock amber turn signal lenses with smoked and run amber LEDs instead. Problem is, I can't seem to find a simple solution.
    The Kuryakyn drop-ins for the rear are red instead of amber, and having spoken to a very helpful fella at Rollies Speed Shop, im looking at over $500 plus shipping for four entire new lights. Does anyone know of a more cost effective solution, preferably drop in replacements the keep the existing stock housings?
    Any advice would be appreciated. Cheers.
  • robots
    robots
    Hi,
    Try the Custom Dynamics- Dynamic Clusters, you can get them off ebay no worries delivered to aus, they are hard wired using posi-connectors, about $110 for rear and very effective
    Thanks
    Robots
    If the 2014 still use bulbs, just replace them
    With amber bulbs ?
    Don't get hung up on the Led hype.
  • OzDarchangel
    OzDarchangel
    Thanks Robots, will have to do some research as there seems a plethora of options. Have you done the conversion using the stock bullet buckets? The running\turn on front and just-turn on the back looks like the go.
  • robots
    robots
    Hi,
    Yeah i done rears, so it goes in stock billet housing, pretty easy, i send you some photos
    Thanks
    Robots
  • OzDarchangel
    OzDarchangel
    Thanks dude. If it's just turn on back it should just use the bayonet fitting for the standard bulb and that should be it. For the fronts, looks like I'm gonna have to run the third lead back into the headlight housing and use the posi-connectors for the front run lights. Doesn't look too difficult.
  • robots
    robots
    Hi,
    If just dropping in the amber LED cluster front and rear then you wont touch the wires as they have bayonet fitting attached to the cluster and just pop them in
    Only when you want to have the running/or brake light function will you attach to wires, like the dynamic cluster2 or dynamic rings
    The other thing, keep receipt they have lifetime exchange if any leds fail, no questions asked, also you may only find the 'flat' style on ebay not billet you can easily take the flat part off, or buy direct from Custom Dynamic
    Thanks
    Robots
  • Damo222
    Damo222
    I brought my last bayonet type LED globes from a truck supplies shop $25 for two globes. Ya can get them in amber or clear.
