Online: beaglebasher, baldy1450
Is this vibration normal?
  • PaulT
    PaulT
    I was on the highway today on the new Street Bob and from about 90kph there was a vibration that would come and go, it got more pronounced the faster I went. At about 110, 120kph it was almost a shudder that would come and go, come and go, in a rhythm . All the wheel weights were in place, is it just a 103 Dyna thing?
    Thanks
  • beagle
    beagle
    They can vibrate at some revs, but Id be back to the dealer getting them to check the mounts, both motor and exhaust. What area are you in.
  • PaulT
    PaulT
    thanks, Im in Brisbane, so my dealer is Morgan & Wacker
  • beagle
    beagle
    I've sent you a pm.
  • adadrian
    adadrian
    I got a brand new street bob and I got normal vibration
  • Ando
    Ando
    I have a new Bob with over 130hp and no problems here
  • Darke_peak
    Darke_peak
    I have a Dyna Switchback which came with the factory vibration caused by poorly designed exhaust mounts. Two dealers couldn't find the problem with mine. One acknowledged there was an issue and the other denied it was a problem. Dyna's vibrate at idle, but there shouldn't be any vibration beyond 2000rpm. Just try and note if it is speed related or rpm related.
