Online: B0nes
motorcycle modification codes of practice
  • fatmatt
    fatmatt
    Hi y'all
    Like 99% of you,i'm interested in what i can and cant modify  (legaly) on my bike.
    there some absolute BS in there but there is all handy to know.
    Reason i.m looking is im now on a GDB for 12 months and ANY infringment car,bike boat or whatever, will zap my last 2 points then im up shit creek big time
    i dunno how to attach a pdf file so heres the link instead
    Scroll down to section LL motorbikes and motortrikes
    I http://tmr.qld.gov.au/Safety/Vehicle-standards-and-modifications/Vehicle-modifications/Light-vehicle-modifications.aspx
    how much is "wrong" with your bike as per this document?
    Vehicle defects don't result in demerit points so you're safe
    Sounds odd. Demerit points are assigned to road safety offences such as speeding, seatbelts, use phone, neg drive, fail giveway etc. Never seen or heard of them assigned to defect related matters or offences
  • Hesh
    Hesh
    So, I found this entry:
    2.1.16 Horn
    An efficient horn or other device must be fitted that is capable of warning other road users of the presence or position of the motor cycle. Horns, sirens or other devices that emit a sound like a siren, exhaust whistle, compression whistle or repeater horn must not be fitted.
    My question is, what is an exhaust whistle, compression whistle or repeater horn?  I have a Mini Beast 2 Air Horn fitted and as far as I understood, it was an allowed horn as it was not, according to the TMR website when I checked, a "multi-toned horn" ie it was not one of those musical ones Dukes of Hazard style?
    Hesh
    Must be a qld thing. You don't incur demerit points for infringements re modifications in the ACT. And probably the same in NSW
