Online: B0nes
Head Light Conversion 2014 Fatbob
  • Brooza
    Brooza
    Not sure if this topic has been addressed, so apologies if it has already.
    I have 2014 Fatbob, does anyone know where i could get a head light conversion so that both of the head lights are lit the same?
    Cheers.
  • FatRob
    FatRob
    I went the simple route and changed the whole light unit.  It is an easy enough task to do and can be done within an hour.
    The US spec FatBob lights have a 'neutral' dip so it is neither to the left nor to the right.  As far as I am aware the only thing that makes that unit non-compliant here in Aus is that it does not have a pilot light and is not e marked.
    Cheers,
    FatRob.
  • Dutchy Hoogen
    Dutchy Hoogen
    I changed the whole unit too. Have the old one just in case law don't like it.
  • fat55
    fat55
    Yep me too , got the US  domestic  unit ,  then bought the wiring kit off eBay , had a mate who could solder took about an hour
  • FatRob
    FatRob
    Mine had all the wiring attached.  Plug and play.  No soldering involved.
    Cheers,
    FatRob.
  • Brooza
    Brooza
    Cheers guys.
