Online: tussuck, FONTANA302
92 883 hugger speedo.
  • Mule2176
    Mule2176
    Hi I was just wondering if anyone can tell me if there is supposed to be globes in these holes?
    They are the ones on the left and right.
  • Colstah
    Colstah
    Here's what mine looks like.
    Quality of the pic is not great, but it should give you an idea. There are lamps in those holes, took one out to show what it looks like. They are held in rubber sleeves/grommets of some sort.
    so yep there you go was going to say yes as most 90s Harleys are the push in type weather it be the rubber type or the metal type
    good one colstah
