Online: imoo6170
pivot shaft
  • gbarratt
    gbarratt
    Could someone please give me some information about the pivot shaft on my 1996 Road King? I have removed it, or moved it, a couple of times, to replace the belt. I last used Loctite Antiseize on it but it seems to be well and truly seized and I have to replace my belt. Is there any solution apart from belting the shit out of it to get it to move ?
    Are you talking swing arm pivot ?
    Sometimes the only way is a BIG hammer and a soft metal drift, or you may be able to use/make a slide hammer.
  • gbarratt
    gbarratt
    Thank you. I thought as much. Bashing will ensue hahaha !!!
