Online: wildchild, Fletch1953, speedzter
Handlebars + Risers = Pullback?
    Are the 4" risers straight or pullback ? i'm guessing straight.
    The difference should be fairly small, maybe 1-2".
    Dont forget, a lot depends on how you have the bars adjusted in the riser clamps.
  • FXST11
    FXST11
    Maybe you can sit on bike, and grab a measuring tape, and put your arms / hands up to approx the height you want. You might need someone to hold tape.
  • Drac
    Drac
    Because of the rake, the higher you go, the more pullback you will have if you keep the bars following the line angle of the forks.
  • beagle
    beagle
    You'll only pick up the angle of the rake with straight risers. Just hold a straight stick in line with the forks and you'll see how much it comes back. Wide glide style front ends come back further than touring models.. I suppose you'll want the 4" risers you sold me back now.. LOL...
