Online: imoo6170
PAINTING ENGINE!!
  • Ajc
    Ajc
    Looking for some different options.
    Have an evo engine. Has been blistered back to bare metal.
    Just wondering if you can two pack the engine and if the etch primer will be ok?? Or is the standard powder coat the go??
    Thanks.
    Isn't two pack just "normal" paint? Myself I'd look into a high temp paint (spray can) or even the shit they paint pot belly stoves with. Color to taste I suppose.
    Sand it all back with wet n dry. Use high temp primer for a coat or two followed by high temp black paint
  • wayne.craft
    wayne.craft
    You can use 2pak, but blasted clean, straight over the bare metal .....
    Undercoat and heat do not mix...
  • terroristone
    terroristone
    Using undercoat will damper the heat transfer....not advised in using it. Much like painting a radiator - use the wrong paint and it will no longer efficiently transfer heat.
    T1
  • Ajc
    Ajc
    Thanks for the replies. All very helpful!!!
    Its amazing what temp' 2 pack can handle.
    you can also buy HD branded case paint.
    vht high temp engine paint in a rattle can black wrinkle or flat what ever you like
    So 2Pack (or 2K) is a high temp paint? Anyone know the rating?
  • Wazza-hg
    Wazza-hg
    I don't know the rating but I painted my motor in a Hg Holden in 2 pack and to worked great. But Hg motors get hotter then water cool motors.
    I asked a friend who messes with a lot of engines and he says 2pack is fine for engines. I learn something every day...mostly...sometimes.
