Narva deutsch plug crimps
  • fatmatt
    fatmatt
    hey blokes.
    im in the process of rewiring the deutsch plugs and wanted to do it properly so I splashed out on the pins and the crimp
    problem is , I cannot for the life of me figure out how to use the damn crimps.
    any and all advice taken.
     I got the Narva crimper btw
    matt
  • fatmatt
    fatmatt
    ok after sifting through the endless replies ( can you sense the sarcasam Ha ha) i think ive sussed it
    I think the pin size is the issue. The std harley pin size is too big for the narva crimps and unlike the genuine Deutsch ones, they are unadjustable.
    looks like i have just wasted 50 bucks :(
    matt
  • FXST11
    FXST11
    Matt, try googling Use of _______.
    also try on doing a search on You Tube
