Online: John.R, Hilly
Query with Reduced Reach forward controls and V&H short shots
  • evilsnoofy
    evilsnoofy
    Thinking of getting a set of the RR forwards if my custom seat on order doesn't fix the 'scooching back on the seat under acceleration so I can't quite reach the forwards properly with my tiny feet' thing.
    But I have V&H short shots on the 48, so I'm not sure whether the reduced reach setup will fit in and around the pipes on the right hand side.
    If anyone has any advice or experience with these, I'd be v. interested to hear!
    Cheers :)
  • Iron Eddie
    Iron Eddie
    Mate, try a search on the xlforum  for an answer.  If no luck try getting the dealer to supply based on your question.  If they are interested in selling you a product they should be interested in making sure it all fits.  If it doesn't i'd be asking for a refund based on consumer law and having the right product, fit for purpose etc etc.  They may or may not be bothered though so good luck!!!
