Removing cooked-on crap from chrome pipes
  • weedoman
    weedoman
    I noticed too late that there was some "stuff" smeared on my pipes. I think it might be oil. Now it's pretty cooked on. I tried removing it with some car wash liquid and a mildly abrasive wash pad. The easy stuff came off but there is some left. Any suggestions to remove the rest? Cut & polish? Chrome polish? How scratch resistant is chrome (V&H pipes)? Bit paranoid about scratching the chrome because it's in a pretty visible spot.
  • imoo6170
    imoo6170
    I have used HD Boot Mark Remover For Chrome Exhaust Genuine 93600069 (about $12 at your dealer) - works quite well.
    I've heard of people using chrome polish, goo be gone (comes under a few similar names) and oven cleaner. Use (patch test) at your own risk as I've never done it myself.
  • steelo
    steelo
    Hi there.
    I've used bunched up cooking alfoil lubricated with plenty of water in a bowl. Dont rub hard. Give it time and it will / should take most marks off.
    Good luck
  • flstc08
    flstc08
    G'day,
    try a plastic knife, or similar.
  • Bashful
    Bashful
    I learnt from this forum to very gently use a sharp stanley knife blade.
  • careyman
    careyman
    probly boot rubber, purple polish got mine off
  • MADOGA
    MADOGA
    cooked on crap ?
    first up dont use your exhaust pipe for cooking
    2nd why are you cooking thats a womans jobs!.
    and dot let her cook on your exhaust pipes either it'll make a mess of them.
    fix it with plenty of time elbow grease and some polish
  • Hesh
    Hesh
    Purple Polish.  Search this forum for previous topics on the product by California Custom.  Great stuff!
    Hesh
  • weedoman
    weedoman
    Yep - purple polish did the trick. Good as new. That stuff is the duck's guts.
  • steelo
    steelo
    Hi there, glad you had a win with the purple polish. Did you try any of the other methods as well. The alfoil perhaps.
  • careyman
    careyman
    i scrape shit off my metal (including knocking the little rust scale spots off the spokes) with an old credit card, strong enough to move the crap but safe to I know i cant scratch anything
    a product called gumsion works well
  • Rob_hendo
    Rob_hendo
    a mate had crap on hs sportster exhaust, used coca cola and alfoil came up perfectly
  • steelo
    steelo
    Dear forum members, I had the pleasure of being trusted to take the young grandson of a member on the homeward leg of a south coast tour today. When I got home, I noticed the young lad had left a sizable portion of his boot melted on my exhaust pipe. Using my earlier recommended solution of crumpled alfoil and water, I submit the following pictorial DIY.
    Some scrunched up cooking alfoil ready to go
    At the halfway mark. Resist the temptation to rub harder. It will all come off. Dip alfoil in water frequently. Rub gently and lightly. The foil drags and you would swear its damaging the chrome. It's not.
    Finished in about 10 mins, just dried with a cloth. They are 10 years old after all.
    Don't use the foil for cooking anymore
  • steelo
    steelo
    In case its a trick question. That's the beauty of it. Borrow some from mum or the missus and it's cost you NOTHING. Cheers
  • wayco
    wayco
    For stubborn stuff try using wd40 instead of water-I've used it & it worked a treat.
  • steelo
    steelo
    Long time since anyone posted on this thread but I didnt want to start a new one.
    Friends, since I bought my Deuce 5 odd years ago, I thought some moisture had gotten into speedo and condensed on inside glass. I could see it all the time and thought at one stage I'd have to pull it apart to clean off. Anyway, long story cut short, saw a youtube about cleaning headlight lenses uses metal polish and used some mothers metal polish on the glass and it came up a treat. Turned up was on the outside and normal polish cleaning wouldn't get it off.
    Looks good now. What do you think? Give it a try on scuffed or dulled glass / plastic
  • Krackers60
    Krackers60
    Well done Steelo, it's come up a treat.
    A earlier post shows that i have had great results from a paddle pop stick, it does work very well
