Online: Stuart
headlight no good
  • beaglebasher
    beaglebasher
    went for a ride last weekend and it got dark about 100ks before i got home. i had to ride down a steep winding hill (macquarie pass) and my headlight was focused about 10 feet in front of the bike. high beam focused about 12 feet away. it was bad enough that i had to pull over and wait for a car to pass and i followed it. does anybody know how to adjust / rectify this problem? the bike was imported and i dont think the headlight was adjusted properly cos the focus is slightly to the right, middle of the road. i will play around with it this weekend but if anybody can give me any tips it would be appreciated. cheers
  • Burnzi
    Burnzi
    Hey Beags, from memory you need to stand the bike upright and aim the headlight at a wall with a line at the same height as the centre of your headlight. I think 3.0m is the correct distance form the wall. This should set the aim right. Remember to allow for your weight on the bike as well. Just wondering about the issue with it shining to the right, an Oz headlight on low beam should actually light up more of the left side of the road. Is a headlight something that is changed during compliance? I'm sure there may be some better advice than mine out there, have you tried youtube?
  • Burnzi
    Burnzi
    Checkout youtube there are a couple on there, just make sure ya get an Ozzie vid. Also google it.
  • rider
    rider
    what model and year BB ?
  • Gonads
    Gonads
    I adjust mine "on the fly" for distance lighting. Do the adjuster up firm so that u can move the light by hand but not loose that it would fall back with vibration etc. Straight road riding slowly, reach over while riding and either lift or lower light till you got the best position, pull over and tighten up. I also run a Narva plus 120 globe which also helps a fair bit.
    If it is shining to the right, pretty sure you will need a new headlight insert. Hella and Narva do them if you don't want to pay HD premium.
    I think I mentioned this before, but my headlight is FUCKED and it's an import. I'd be interested to know (PM me) who did your complancing, but your problem is probably just a matter of adjustment.
  • beaglebasher
    beaglebasher
    thanks for the replies folks. i adjusted the headlight up a bit but its still pointing slightly right. its a 2002 fatboy. i havent had the chance to take it out at night yet though. i will get on you tube and check it out further.i will check out the headlight insert,i think it needs something like that. thanks again
  • beaglebasher
    beaglebasher
    sorry bonkerz, dont know who did the compliance.
