Shovelhead friendly auto electrician
  • shadowhand
    shadowhand
    I have a Shovelhead wideglide that needs all the wiring done.  The wiring is brittle, patched, wont start, indicator problems and generally fuked.
    Anyone recommend a reputable, Shovelhead friendly auto electrician in Perth,  SOR?    (Will need to upgrade to modern connectors).
  • jacko88
    jacko88
    yeah mate I know of a good one switched on with HD's I just need to get his details from a FIFO mate when he gets back this weekend
  • jacko88
    jacko88
    not as easy when it comes to the handle bar wires when converting to late model switches, the rest is pretty simple. I would suggest an 84 to 86 FXWG as when I did my 86 FXWG I only had to swap a couple of wires differently to fit twin cam controls. Pics are all gone now but seeing kiwidave has pics of my frame he may have the wiring as well :)
