Online: paulybronco, B0nes, Trunksie
chrome plating
  • SoftailSteve
    SoftailSteve
    anyone had some chrome plating done and who did you get to do it?
  • Blue Dog
    Blue Dog
    I would not mind knowing that as well. Some of the chromed exhaust shields have pit marks. Hope they can re-chrome the parts.
  • Ranger
    Ranger
    I recently had a brake pedal modified which then required rechroming.
    This came with a warning that "chromers are a law unto themselves who wont prioritise or do rush orders" so even though the pedal will be cut, shortened and rewelded within a day or two, it could then take up to a week to get it back from the chromers.
    The bike store sent the pedal to "A Class Metal Finishers" in Lonsdale Adelaide.....apparently the best in the business.
    Three weeks later following multiple calls and still no sign of my bike, I had them retreive the pedal from the chromers (still unchromed) and put back onto the bike as is.....the bike store kindly sprayed a little silver paint onto it.
    I then took the pedal into "Chrome Masters" in Salisbury. Dropped it off just before closing on Monday afternoon, picked it up on the Wednesday around lunchtime.................I now know who my chrome platers will be in future!
  • Crowy
    Crowy
    Huntingdale Electroplating
    Address:23 Shafton Street
    HUNTINGDALE VIC 3166
    Phone:(03) 9544 6079
    Fax:(03) 9544 0687
  • fatmatt
    fatmatt
    I had a set of apes chromed by gold coast electroplating in biggera waters
    told it would be two weeks
    went back after two and was told another week
    went back after now three and they fucked it
    went back after 4 after they fixed it and then charged full price.
    had to grind back the bar ends for the grips to slide over but thats prob a good thing ...lots of chrome layers
  • SoftailSteve
    SoftailSteve
    other than the helmet and 1 grab rail this is the parts that need chrome plating (photo of another forum)
  • FXST11
    FXST11
    I used to get all my chrome work done for my Cars I showed,
    at All Model Bumpers
    Malta street
    Villawood,,,
    just off Woodville road
    in Western Sydney
    Malta st Villawood  i think are called Superchrome  same factory as All Model Bumpers from the70's i had all my chooper chrome there done  in 1975
  • SoftailSteve
    SoftailSteve
    Astor Metal Finishes
    Electroplating
    93 Malta St, Villawood, NSW(02) 9727 5622
    All Models Superchrome (Villawood)
    Metal Polishers - Villawood, NSW
    93 Malta St, Villawood NSW 2163
    Phone
    (02) 9727 5322
    thats where i had my wheels done. same place
  • Colstah
    Colstah
    Only thing I can add here is look out if you get them to polish the parts first. I got some hand controls chromed here in Adelaide and they just about rounded off the flat section on the master cylinder that the brake line bolts to. Had to use an HD rubber washer 'cos there wasn't enough flat for a copper washer to make a good seal.
