Online: Stuart
Vance & Hines Pro Pipe dyno results, anyone?
  • Bashful
    Bashful
    Anyone used the V & H pro pipe 2 into 1?
  • Chewbacca
    Chewbacca
    Bashful I have a set on my 2013 fat bob what would you like to know?
  • Ando
    Ando
    Bashful is talking Pro pipe not a Comp pipe
  • Bashful
    Bashful
    Well, I figure I have sunk a bit into the donk why stop now. I might aswell to the exhaust to maximise my gains. I allready have stock headers, 3" python mufflers with no baffles, stock mufflers, V & H 2 into 2 big radius and a set of Supertrapp mean mother shorts.
    Its so confusing, Lushy shows good gains with the stock headers and S & S mufflers but would a good 2 into 1 give more, less or the same as Lushy's demonstration.
    There is plenty of opinions on exhausts but I still have no firm evidence that 2 into 1 give better gains. Anyone now for shore? Anyone? Someone FFS?
  • sag57
    sag57
    lf you do a search on the v&h pro pipe hopefully you will get the dyno run that l posted. l have the pipe s&s 585 cams , S&S teardrop air cleaner ,screaming chook module and a 103 kit in an 09 dresser , maztech in Melbourne got 103 hp and 122 trq , prior to the 585 cams l had se 255 cams whitch came with the 103 kit and if my memory was right it was 92hp and 103trq. The bike has been dynoed by 3 different tuners with different engine specs but all three tuners loved the pipe for the torque they generated. lf you look in the product reviews l did an article on the propipe and like l said in that the biggest letdown was the quality of the finish. Hope that helps you
  • Bashful
    Bashful
    Thanks for you imput all.  After much reading I have decided to use the opinions of Davo and Lushy who have posted priceless info.
    S & S slip ons and stock headers for me.
