Online: baldy1450
Truck light led headlamp
  • zerocool
    zerocool
    Hi guys does anyone have or have used this headlight ? Wanted to know if it was any good before I buy
    http://www.ebay.com/itm/141218250097
    thanks
    steve
    Steve does your street glide not have a similar light as std?
  • zerocool
    zerocool
    no its not led wished i would have added a led one from the dealer
  • zerocool
    zerocool
    thanks
  • rider
    rider
    I fitted one to my '12 FLHTCU, reckon because it also uses reflectors is why it out performs the HD job.
    Can't go wrong, and that's a good price as well.
  • zerocool
    zerocool
    yer much cheeper thanks again
  • coffy
    coffy
    I have read some awesome reviews on these lights on US sites, with all reviews being nothing but full of praise for them, and being half the price of HD daymakers, have decided to purchase a set for my Roadking
  • coffy
    coffy
    http://www.youtube.com/watch?v=KPX5b60Hse8
  • zerocool
    zerocool
    thanks guys lamp on order will let you know how i go
    steve
  • puz
    puz
    correct me if i'm wrong but i thought if u import a US model bike,one of the things that needs to be changed is the headlight because of the reflectors directing the light to the wrong side of the road ??
  • Fe883
    Fe883
    Correct,
    But a lot of these lights you can order from the US you can get as a R/H/D or L/H/D unit.
    Cheers.
  • keith
    keith
    I bought and fitted the genuine HD LEDs ex USA half the price over there, around 1k here in Oz from your local dealer for the 3 lights !, to my surprize they are not a sealed unit first time in the rain they started showing signs of moisture inside. The good old genuine HD part not what they are touted to be! Do chuck out awesome beam though on the upside.
    Phase 7s look the goods.
  • puz
    puz
    Cheers fellas...appreciate the replys
  • keith
    keith
    I've been going to the same dealer in Ventura for 4yrs now, had my whinge about the lights taking on moisture, will get a in shop credit to spend and keep the lights Going with the Phase 7s.Buying in the US I think has more upsides $$$,this is my only lemon so far.
