What are these made of?
  • Superglide2012
    Superglide2012
    Can anyone tell me what these are made of? I went to polish and now all I have is scratches. I tried purple polish and it scratched. surface was clean, microfibre cloth used etc. Purple polishes chrome beatifully but not these.
    Thanks
    plastic cheeky
    cast iron  or aluminuim  than chromed
  • Superglide2012
    Superglide2012
    Plastic? Hahaha
  • mickle
    mickle
    Polished Aluminium.
    Aluminium alloy isn't it? I've seen people use a REALLY fine grit sandpaper and Mothers aluminum polish with a REALLY soft cloth - not microfibre.
  • Superglide2012
    Superglide2012
    Bonkers I thought so. Thanks. Off to get aluminium polish now. I'm not sand papering it. Cheers
    Any excuse to get your bike in a pic hey dude. BTW, Some say they are made of Plasticine, but i think they are made from chewing gum!
  • Superglide2012
    Superglide2012
    Hubba Bubba or PK?
  • Pastrypete
    Pastrypete
    is your head light after market ? if so was it easy to wire in ? cheers Pete...and just polish with mothers and a microfibre...works on mine
  • Superglide2012
    Superglide2012
    Hi Pastrypete. No it's a genuine harley light. I had it put on the bike when I bought it. As for wiring they did it at the store I bought it from. As for mothers you mean mag and alunium polish don't you?
