starter motor issues
  • Will67
    Will67
    hi all fucking bike im layed up with a work injury and have been periodicly starting the bike now and then.
    battery is good starter just clunks but doesnt turn over. i ripped the primary cover off and the starter cog wont retract unless i push it in with hand.
    any ideas wtf it could be im feeling exspesive for a new starter motor.........
  • Will67
    Will67
    sorry i should of mentioned its a 2010 softail standerd with 10000ks
    are you sure you have a fully charged battery or was it having symptoms before you parked it up ,may pay to put here on charge over night
    try again before you rip it out starter should be ok with only 10,000 ks
  • Will67
    Will67
    no tested battery fully charged mate
  • AJ56
    AJ56
    Have the battery load tested... I bet on a stuffed battery... They can be fully charged but lack the cranking amps. As they can't hold the charge.. and lack the recovery capability..
  • Will67
    Will67
    thanks guys, il get the battery load tested and let you know. have checked cables and connections appear fine.
  • Will67
    Will67
    THANKS ALL,
    had battery tested and load test failed, new battery in alls good : )
    but have to admit the genuine HD battery in it i only bought over 12 months ago and have used a battery tender on it since new so fucks me.
    bring back ta kick starter
  • roger paul
    roger paul
    The main problem is 10,000 k's in 4 years - you are not riding it enough!!
  • roger paul
    roger paul
  • Daggs
    Daggs
    My battery is the standard one, always have it on tender if not riding it in a week or more, nearly 7 years old which is the best I've had from any vehicle battery fir a long time
